1927 broken oil pump spring
BEarle
Does any one know a supplier for the fine oil pump spring? Mine is broken in half.
Thanks.
Brian
Thanks.
Brian
Do you mean the main return spring for the plunger, or the small spring on top of the distribution valve in the top of the pump.? if the latter, then any good hardware store will have a selection of small springs for you to choose form. This spring regulates the pressure reading on the gauge. (Not the actual oil pressure itself, just the gauge)0
It is the small spring on top and my guage measures zero. Thanks for letting me know it is just the guage reading. I have not driven the car for fear I have low/no oil pressure.
I hve tried local hardware stores with no luck finding the size and compression rate.
I really appreciate the help. I drove this car to the 1963 HET Meet in Elmira, NY.
Are we talking Hudson or Essex? I can make one for you and post.0
It is the F-head Hudson. That would be wonderful.0
