1937 Terraplane throw out bearing Wanted
Donald
Hello, I am new to the Hudson world and looking for a throw out bearing for a 37 Terraplane. The throw out bearing assembly is made up of two parts. The bearing and the cast iron sleeve the bearing is pressed on. I believe the bearing was used for many years and the cast iron sleeve was different over time. I need the cast iron sleeve . I suspect Hudson used this sleeve for a few years, I expect to purchase a assembly but can purchase a new bearing if I had the sleeve. Can you help? Thanks, Don Feeney 740-816-4284
Wildrick’s has rebuilt TO bearings for $200 including a $50 core charge for your old one. https://www.wrphet.com/1930s-hudson-parts/1930s-hudson-clutch-parts0
Thanks for the information, I don't have a core to turn in. I'll check to see if I can buy one outright.
ensign bearing company jim ducharme elk rapids michigan e mail jim@ensignbearing.com have purchased from him great prices great service quick delivery. has been in business for many years. price will be far less than 200.00. he has seals, brushes ,bearings and MUCH MORE.0
I have plenty of them ..... in Aust. This may be of interest. Thanks to Frank and Phil. Sorry but you have to twist your head for a smile
I no longer one
or your local bearing supplier.Bearing, Throwout New Departure CT26 Ron Fellows
- 120 Hudson 1916 - 1929
- 612 Vehicles
