Mechanical Brake System Springs
You can buy new drum brake hardware kits at Napa. It includes all the springs, pins, keepers and adjusters.0
There not on the wheels they are underneath the car by the master cylinder. There’s either 3 or 4 I don’t have any , They took them off to build a gate or so I was told it’s one of the hazards of buying a field car little things get taken off to use somewhere else. It’s a 52 hornet iam trying to piece it back together. John0
Hey Ken, said that direct link wasn’t allowed when I clicked on it0
Sorry, I forget that the blocking code is active.
If the car is run without them is it a bad thing?0
Thanks Ken ,This is exactly what I needed John0
ACE HDWR has a good selection of these springs. I used some for that purpose.0
Look in old school hardware stores0
Its not too hard to make your own springs with a drill and blocks of wood, plenty of YT vids on the subject. Spring wire comes from Amazon in a range of diameters.0
