Twin h fuel blocks
Hello
Does anyone one know the dimensions of the twin h fuel blocks thread sizes etc trying to find something in Australia.
Thanks
Steven
  • Fuel blocks? If they are tapered pipe threads they will be NPT, not common in Oz but findable. Similar to BSPT but usually a slightly different TPI.
  • It’ll be 1/8” NPT where it threads into the carb, then it’s 5/16 flare
  • That is a coincidence I have just taken delivery of the following from Rockauto:
    This is 1/8 NPT male to 5/16 pipe thread (1/2 x 20 UNF) elbow, to fit the rear WA1 carb on a twin H set up.
    Delivery to the UK was only a couple of days, maybe they ship to Oz too.  I ordered up a number of other things from Rockauto as well, so well worth browsing through their listing for Hudsons.
    Hope this helps.  Regards, Brian.
  • ratlee2
    edited March 2022
    If you are talking about the tee.  It is 1/8" male npt at the carb and two female to 5/16" inverted flare (1/2 x 20 UNF).  I had difficulty finding them even online.
  • 50C8DAN
    edited March 2022
    I scrapped the stock fuel lines and put in stainless steel Swage fittings.
  • Found some at a hydraulic parts supplier
