Twin h fuel blocks
Fuel blocks? If they are tapered pipe threads they will be NPT, not common in Oz but findable. Similar to BSPT but usually a slightly different TPI.0
It’ll be 1/8” NPT where it threads into the carb, then it’s 5/16 flare0
That is a coincidence I have just taken delivery of the following from Rockauto:This is 1/8 NPT male to 5/16 pipe thread (1/2 x 20 UNF) elbow, to fit the rear WA1 carb on a twin H set up.Delivery to the UK was only a couple of days, maybe they ship to Oz too. I ordered up a number of other things from Rockauto as well, so well worth browsing through their listing for Hudsons.Hope this helps. Regards, Brian.
If you are talking about the tee. It is 1/8" male npt at the carb and two female to 5/16" inverted flare (1/2 x 20 UNF). I had difficulty finding them even online.
I scrapped the stock fuel lines and put in stainless steel Swage fittings. 0 -
Found some at a hydraulic parts supplier0
- 101 Essex Super 6
