54 Hornet Visor
54 takes a different visor because of the one piece windshield. You have to drill holes in the roof like on GM visors. Good luck trying to find one.0
They are different due to the fact that the 48-53 front windshields were divided. In 1954 they were one piece so the entire outside visor was redesigned to reflect that. They were not as popular by 1954 and few were produced . Very rare item.0
By '54 the visor look was pretty much over and cleaner uncluttered look was the norm. my guess is that even '52 - '53 most were not crazy about putting on visors.0
Dan is right. The look had become passe. There's one picture on "hudson visor" on pinterest which, of course can't be linked here.0
This one? I think that's the first 54 I've seen with one.
Having a visor prevents you from rotating the radio antenna when you want to put a car cover on.0
The use of a variety of visors from the Fulton meant for the 1948-53 Hudsons to Fulton and other makes that fit the profile of the roof have been used. The attached pictures are of a few that I have seen and collected installation pictures. Hope these will bring some clarity into the 54 Visor scenarios Good luck;
Most car cover companies will tell you to cut a small hole in the cover for the antenna to stick out, they even provide an adhesive grommet to put around the hole to keep the hole from tearing out. Many collector cars have antennas on various parts of the body, fender, roof, trunk, etc.29sptphaeton said:Having a visor prevents you from rotating the radio antenna when you want to put a car cover on.0
- 81 Hudson 8
