How to install sail panels on 52-53 rear window
Kdancy
The retainers were totally rusted out. Does anyone have pictures on the retainers used
to attach the rear sail panels?
52 Wasp Sedan
Dang.... That's the same car?0
I was unable to locate some for the front windshield trim for my 53 Hornet and ended up using chevy nova rocker trim clips. They should also fit the rear as well.
https://restorationpartssource.com/store/rocker-molding-clip-1962-72-nova-kit-oer-details.html
ratlee2 said:I was unable to locate some for the front windshield trim for my 53 Hornet and ended up using chevy nova rocker trim clips. They should also fit the rear as well.
Thanks for the link, I will order those today.
superwasp said:Dang.... That's the same car?That was the original car that became a donor for a Texas 52 Pacemaker made in early 52 before they switched to the Wasp name. There are some differences between the two.Even that desert hudson had rust issues that I had to cut out and weld in panels along with a lot of roof work.pictures --
Painstaking work for sure. Is that Symphony Green?0
- 97 Essex Super 6
