figuring out the junction box on a 1930 Hudson
The Junction box/light switch is a real rats nest in the 1930 Hudson Super 8 that I just bought. So far I've determined which wire is the hot wire feeding it and the headlight terminal, brake light terminal, fuel gauge junction terminal. But chasing the other wires is difficult since they are mostly all the same colour. I have a 1931 instruction book and in it the diagram of the junction box is a total different shape, so I'm guessing it changed shape in 1931. Does anyone have an illustration of the 1930 one?
I don't know the proper name for the components, but the non-conductive fibre plate is badly worn, and I'm wondering if I could just rebuild it using JB Weld by filling in all the worn recesses and bridging the one spot where it has completely worn through. Unfortunately the first picture got posted upside down for some reason.
Going on your picture, clockwise from the terminal with the yellow insulation strip, Battery, low beam, high beam, side lamps, rear lamp (also dash lamps). The bottom row are just terminal blocks.0
The insulating material from which your badly worn plate is made can be bought, drilling a new one would probably be easier and a better job than trying to rework the old one.0
bob ward said:The insulating material from which your badly worn plate is made can be bought, drilling a new one would probably be easier and a better job than trying to rework the old one.0
Phenolic? McMaster Carr sells it.0
A separate junction block and a push/pull headlight was the repair when they were daily drivers.
Weren't concerned about original.
You have a challenge at hand to repair that , but doable.0 -
I've just repaired it, and as a dry run, the brass ring with the 3 bumps seems to be moving freely across the repaired areas. I'll post a picture tomorrow.0
- 107 Hudson 1916 - 1929
- 564 "How To" - Skills, mechanical and other wise
- 175 The Flathead Forum
- 603 Vehicles
