232 head on 7X 308
Rudy Bennet is said to have posted some awhile back...???
Martin, I will take pictures of the 7X 232 iron cyl head showing the Modified chamber and the Factory Part Number stamped on top of head . Tomorrow and send them.
Rudy Bennett0 -
Rudy, any chance you could post the photos here? I have two 232 heads that are drilled for 1/2" head bolts, (one, on a known 7x engine) I would like to compare with another that I have, that I'm sure is not 7x. (7/16" holes)0
Yes i will do that .I hope to have pictures on here by Saturday . Rudy.0
Thank you Rudy. By the way, I still have the headers on my 41 coupe that you made back in the 60's. This is Dick Thorp's old car, and may have been owned by Jay Allen by then.0
Thanks 54 I remember that car very well as Dick and I used to trade info as to the 308 engine in making them run very well. ( is it the one that all 6 cylinders go into and tapered long tapered loke a MEGAPHONE ? )
Also, have you ever seen a 3 carb manifold with 3 of the WA-1 carbs on it ? Me and another local hudson racer built that cast Iron intake and it is very,very Heavy and my friend loaned it to Jay Allen but he never gave it back and just Faded away.:
Pal Rudy B.0 -
Rudy... the three carb intake ended up on one of the Twin H Ranch cars at Fontana. I saw the car a longtime ago, an early 2 door sedan stepdown if my mind is telling the truth to me.0
Thanks Glowplug very much. Jay promised us that he would take very good care of it and he would have it copied so others could see and fell the difference in the power of a modification like 3 WA-1 over 2 of them. I had it on my 1954 Hornet and even though i did not get a Timed Run on the Strip , the 308 would out run the cars that i could not on the street with the stock 2-ownes. No turning at all just bolted it on and lower the Idle just a bit. If i could find it i would try to Trade or offer the Green-Backs for it.
Pal Rudy Old Timer Bennett0 -
It is two, three into one tapered megaphone style.super651 said:Thanks 54 I remember that car very well as Dick and I used to trade info as to the 308 engine in making them run very well. ( is it the one that all 6 cylinders go into and tapered long tapered loke a MEGAPHONE ? )
Pal Rudy B.0 -
Thanks 54 and it was Harry Grossel who designed them. They would make the 308 out sound some of the big V8 And harry was very good at Spooking the driver next to him with that Big 6 HORNET and he would cause a driver to Red-Light, I could out run him on the street BUT on the strip he would get me as he could cut a light and i could not
Thanks so much Rudy Bennett0 -
Pictures of the head would be great to see!0
Posted per Rudy Bennett’s request-
We removed paint and this # was stamped where the original one was cast into the 232 7x Head. The factory did this stamping as the engine had the head and oil pan and front cover on it.
Was there also an aluminum 232 head that 7x engines uses? Currently trying to accumulate some 7x parts to build one
I have a 232 head from machine shop - ready to go. In SLC, UT.If interested I will come up with price. Gert
It is steel head not alum. Gert
I have these available, same CR as 232, but with revised combustion chambers
Gert. I will be sending you an email. I am looking for the steel 232 to drop on my 262 wide block. My 1951 Super 6 is very period correct and this head swap is something I have wanted to do for years.
Thanks,
Chris
Gert, your email comes back as undeliverable.
I do not remember if email is old - new is HETgtkristi0@gmail.com (remove HET and 0 is zero. Gert
Sent.
Thanks,
Chris
Chris -not recd - Gert
Gert, I just sent again from a Hotmail email. Check your spam/junk folder in case.
I received the 232 head in great condition. Thanks Gert! This is the first time I have seen all 3 Big Six heads together for comparison.
308, 262, 232
Chris, thanks for the pictures.
This is also the first time I have seen all heads laid out together to view their individual characteristics.
