34 Terraplane top speed
Odd , did you check vacuum with gauge at 35 mph?
You might have a restricted exhaust, or maybe a burned through intake.0 -
Ignition timing, valve timing, fuel starvation, poor spark. you need to go through the whole gamut. How did he "block" the heat riser?0
He made a cover out of 1/4" steel and a cork gasket and blocked the area facing the carb0
This might be a stupid question, but did you adjust the brakes?
Yes the brakes have new cables and are adjusted but thank you for inquiring.0
Back to the heat riser, I take it that the stuck butterfly and shaft and lid were removed and the resultant opening on top of the inlet manifold was blanked off?
There is a hole in the underside of the inlet manifold to locate the lower end of the butterfly shaft, make sure that hole was also blanked off.0 -
Thank you Bob. I will check that tomorrow and get back to you.0
Are you sure it’s not too warm for a cork gasket?
regards, Tom0 -
Toddh said:My cable brakes are as good as the juice brakes on my later Hudsons. If they have the correct brake lining material, are correctly installed and adjusted and the cables and conduits are adjusted and lubed correctly they work superb.
My '34 Eight cruises nicely at about 50 mph but only when I can leave a large gap between me and the car in front !0 -
I was wrong about the cork gasket. It was some sort of fiber but still scorched. I put the plate back on awaiting a rebuild kit.
Here is an update on my direction regarding my 1934 Terraplane KU! I am taking all of the feedback and recommendations I have received on the HET Forum to a new mechanic recommended by a fellow club member. I will be delivering the car in October and will report back on the Forum with anticipated success. Thank you all!!!!
- 104 Hudson 1916 - 1929
- 172 The Flathead Forum
- 599 Vehicles
