1929 ESSEX
2manyprojects
LOOKING TO BUY A TIE ROD FOR MY ESSEX. THANK YOU PAUL
The whole thing, or just the ends? Chrysler '36-39 ends will fit.0
the complete length, the ends are fine. 16k mile barn find was moved with a tractor and bent the bar section of the tie rod.0
Just straighten it. any engineering shop with a press should be able to do it for you.0
geoff, is the tube hollow or solid ? thank you0
geoff, do you have a straight one you can measure the correct length. since mine is really bent. maybe a picture or reference from which points you are measuring. thank you0
The tube is hollow, but quite a heavy section. Can be straightened cold, using a hydraulic press, or even a large stillson and a good heavy vice. When straightened you will have to re-set the toe-in.0
do you have a straight example that can give me the total length. concerned when it bent the metal could have stretched so will need a total length. thank you0
It's not that important, as the rod is adjustable with left and right hand threads at opposite ends. You set up with 1/8" toe-in at the rims.0
