Radiator cap for 1935 straight 8
TerriblePain
in Hudson 8
My cap is missing it threads into the top of the water level gauge portion of the radiator.
I can't even find a picture of what the cap should look like...let alone find one for sale.
Is it true that these coming systems were not pressurized? I found something in a manual stating the a 4 psi cap was available for cars that frequently drive up hills.
Thanks.
Thanks.
35 is an open system, not pressurised, you can drive it without a radiator cap. Stuff an old sock in the hole to stop water from slopping out.
36 was said to be a semi-pressurised system whatever that means.0 -
My ‘34 has a machined brass cap. I’ll take a pic of it for you and post here0
radiator cap of my survivor 1934
If anyone buys the assets of northwest auto supply in Grand Rapids, they had them and the original thermostats too.Regards, Tom0
This is a home made 35 radiator cap, I couldn't find a usable original.
Radiator water and gunk get into the fine threads then dry out and glue the cap in place if the car is not used for a while, the cap can be tough to remove even using a spanner. I've learned to take the cap off when I put the car away.
I was able to remove it on my survivor of 1934.Yet at the stop since 1954.C is a very good model
- 612 Vehicles
