Help needed decoding two numbers
Bitburger
Help needed decoding a 308 serial number 7300031 and a Hydramatic Trans H51-26174
The transmission is a 1951 Vintage Hydramatic built and installed in a 1951 Hudson. The engine number has too many digits ... the"7" does not belong in a 308 Serial number. The engine decoder sheet appears on my website ... thanks to Fred Pinder.
The block casting number is 310111 which per the website you provided (thanks), is a 1954 block.Glowplug said:The transmission is a 1951 Vintage Hydramatic built and installed in a 1951 Hudson. The engine number has too many digits ... the"7" does not belong in a 308 Serial number. The engine decoder sheet appears on my website ... thanks to Fred Pinder.
The number 7300031 is stamped in the usual vin location on the block. The Butler book appears to have it as a 1954 model 7D which began with 7269066 and up, but I was also curious about the 00031 digits and what they represent.
Pic attached best angle I could get.0 -
Maybe it is just me, but I can not read the numbers in the picture you attached.
It's upside down due to it being in a tough place in storage. It is 7300031ski4life65 said:Maybe it is just me, but I can not read the numbers in the picture you attached.0
