54 Dana 44 axles: how many splines?
My research shows me that a 54 Dana 44 rear end (out of a Hornet), should have 1 1/2 in axles with 19 splines. Is this correct? And is this the correct spline count regardless of the gear ratio?
Brad, I'd say pull an axle and count the splines0
I'm just trying to check parts availability before taking anything apart. That's why I need the spline count.0
There are no differences an any of the 52-54 Dana 44 rear axles . 19 splines on all.0
Ok Thanks0
