Stepdown Water pumps-6 and 8 cyl- New/ Rebuilt?
Packages are not marked as to new or rebuilt, only say replacement
6 cylinder box is gone
See photos
$65 each plus shipping
Send zip in private message
Thanks
Roy
  • Is this a fair price, need a little feedback.
  • The one with 14P4 on the box doesn't make sense... 1948-52 six cylinder (all)... 1955-56 Wasp. The Wasp engine is the 202 Jet. The big six and the Jet don't use the same water pump. I haven't priced a Hudson water pump in recent memory, so I hesitate to comment on that.
  • '55 -'56 Wasp has the same water pump as Jet, but the shaft is longer.  if you want to use it on a Jet you have to  press the flange closer to the body. As stated, these will not fit the big motors.   Step-down 8's are different pump too, but the guts will transplant to to 6's.     $65 is a good price.
  • So , the 14P4 pump is 48-54 Stepdown , correct?
    I questioned the label also, but the pump looked familiar.
  • I have a Wohlert 14P1 and a 14P5 pump tucked away someplace. If I remember correctly they say "New" and are not painted black. Of course, I could be wrong.
  • They were bare metal with a rust haze. I wire brushed them and sprayed them to preserve them.
    I believe they are new, reboxed to Airtex number
  • bump to top
  • 6 cyl pump is sold
    Eight cyl pump is available- make reasonable offer
    Thanks
    Roy
