New cork clutch chattering when it is being reliesed
super651
low millage rebuilt cork clutch chattering when released when it is Cold. but when it is hot it is very smooth. can you use ATF OIL ??
Dexron 30
What clutch fluid have you been using?
Some years ago the re-done clutch in my '37 was chattering slightly. I started using Dr. Doug's version of Hudsonite, and the chattering went away.0 -
A big thank youall fo the info each one gave to Me about the Chattering clutch.
We will try the Dexron 3 oil in it later in week. RUDY B.0 -
did you have the pressure plate and flywheel surfaced? If the surface isnt smooth it may not be the clutch.
The clutch no longer a problem as we drained out the ATF and installed one 6 oz container of Clutch fluid that i found hiding in the trunk. The HET Club used to sell it and i never tried it until today, The cork clutch is now Smooth as it should be. I just never trusted it before, now I am a believer of it. Thanks so much to all. Hudsonly Rudy B.0
Glad to know Rudy!
- 102 Hudson 1916 - 1929
- 90 Essex Super 6
- 28.5K HUDSON
- 558 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 77 Hudson 8
- 597 Vehicles
