First 2 Twin Vortex Heads are done!
The first two heads completed machining yesterday and they will be leak-tested today.  Then they are off to final inspection and on car testing.  So far so good!
https://www.vzmessages.com/ol/6dc014c4d034ae7ae712e4c567566cd36153ec85
  • Looks great
  • Sharp workmanship! Are you making a few extra heads for slow wallets like mine?
  • I like the look at the new head. It does look sharp. I'm looking forward to the day when I can get mine.
  • 50C8DAN
    edited April 2023
    I will make a handful extra beyond what is on order to meet the min required number for the price I was given.  However, anyone ordering a head after the current run is done will see a price increase so I would not wait too long if you want to get one at the introductory price.  It remains to be seen if we will make any more after this run.
  • What compression ratio will this head produce on a standard bore/standard piston  262ci?
  • 308 is 8.4, 262?  probably around 7.6 to 7.8.  However, you could easily mill it down to increase the CR as there is plenty of material to do that.
