Help needed with a 212 ID
I have a 212 motor with the following numbers and am trying to figure out what year it is.
On the top of the block rh side between cyls 1 and 2 is: 3182308
the casting numbers are: J110
165610
CWC
1
165610
CWC
1
Casting #165510 apparently used in 1946 and 1947
Get serial number on drivers side of motor block, at side near front, below cyl head.
This will help the most.0 -
I got tripped up on 31XXX for cars and 38XXX for trucks so looks like I have a 46 motor0
The block was cast Oct. 11, 19400
So if the casting number J110 indicates Oct 11, 1940 and the numbers stamped on top of the block are 3182308 indicating a 46 Super Six by the VIN numbers from Butler's book then what do I have?
A 1940 block that sat out the war and was finally VIN stamped and put into a car in 1946?0 -
After more cleaning and closer inspection, the casting number is in fact J116 so looks like this is a 46 motor. Thanks to those who responded.0
