‘53 Wasp AC Fuel pump to block gasket thickness?
Can anybody tell me the correct thickness for the AC fuel pump to block gasket on a ‘53 Wasp please? My existing one is a little over quarter inch thick consisting of 5 thinner gaskets packed together. Is this normal? As the gasket thickness would control the amount of contact between the fuel pump lever and the cam I assume that thickness is important. Thanks. Bill.
What you already have will work just fine.0
OK. Thanks Lance.0
- 101 Essex Super 6
- 612 Vehicles
