One inch freeze plug
Try any NAPA store. Clean out the hole and apply a coat of permatex 1. Install the freeze plug and tap the center with a punch.0
Thanks for the replies. The verification that it is a one inch is very helpful. There is a cover at the back of the camshaft, I do not need one at present, but curious if they are available. Hudson308, is your frost plug kit brass?0
The plug at the back of the camshaft 1 13/16 inches and it is harder to find. They are steel not brass and are installed in the same manner as frost plugs. You can get 2 inch brass frost plugs for the left side of the engine block at most auto parts stores.0
- 596 "How To" - Skills, mechanical and other wise
