Overdrive clutch
I know on step downs, 9” was for non OD cars 10” optional but if you OD 10” was standard0
Jet is dry clutch, and is 10", but the parts book shows different numbers for o/d. I have three plates, and they are all identical. I assume the o/d disc is heavier duty, but how does one know?0
Maybe all three of yours are HD?
I would guess the center hub springs might be different?0 -
No, the three I have are the part number for the standard clutch. I have had trouble with a rough clutch, shuddering on take-off, so I think it is because I have the wrong disc in.
Don't want to fit a new disc and have the problem recur. I know the clutch is the same as Studebaker and Chrysler, but can't get anybody to verify the difference.0 -
These photos are a clutch disc I got with a group of Jet parts I bough from someone. The friction portion is .285” thick. Is this the same as yours?0 -
Deleted0
This came from an overdrive Jet. No numbers.0 -
Thank you for this information. In the end, I finally found the data in the 1953-'54 Mechanical Procedure manual supplement, which states that the only difference is the springs in the disc, and is identified by a ring of white paint around the hub. I looked in my spares, and have a new plate in the original wrapper, but the number is obliterated, and Voila! It has a ring of white paint around the hub! To quote scripture - "Seek and ye shall find".0
Great news0
The only reason that I have had "shuttering" was because of a warped clutch disc. I have had several NOS ones that were warped. I was always taught to lay the disc on a flat surface and check to ensure that it doesn't rock.0
For a short time I was out of work as a machinist and worked for a friend at a clutch rebuilding shop. Most newer clutch disc and pressure plates were replaced not rebuilt but the more expensive or hard to find and bigger truck we rebuilt. (Some forklift clutches ran in oil.) Anyway I would drill out the disc pads leaving the bare metal plate.Then another employee would place the plate on a flat surface and if it rocked he hammered it flat . Finally I would use an auto feed pedal controlled rivet setting machine to set brass rivits in the new pads. Long story short the factory NOS Hudson disc should be flat from quality control before shipping long long ago. Too late to do much now except as 7X suggests to check for flatness. Gert
- 112 Hudson 1916 - 1929
