Rear bearing 34-35 gearbox
tigermoth
Hello, on my 1935 Terraplane, the Welch plug in the gearbox rear bearing pops out. It appears properly “set” but I have had 2 consecutive plugs pop out after a few hundred miles.
I THOUGHT I had the correct diameter Welch plug.
Regards, Tom
I assume you mean the layshaft bushing housing? If you hammer the plug in too much the layshaft may be pushing it out. the plug should eb a tight fit to start with, and just hammered enough to spread it into the recess tightly.0
Geoff, that is correct, the lay shaft, bushing housing.Regards, Tom0
Deleted post0
Another deleted post0
- 115 Hudson 1916 - 1929
