Just so people are aware
PaulButler
PaulButler Administrator
edited March 7 in HUDSON
I am moving parts of the website around over the next few days.
Part of that is that is because this forum needs to be upgraded to a later version of PHP.
Because the underlying software is old it's not a simple job so there will be periods where the website will not be available to use and that period may be a couple of days.
  • Jon B
    Jon B Administrator
    Thanks for undertaking these necessary changes in order to make the thing work more smoothly.  And thanks for the years you spend keeping the forums humming along.
  • onerare39
    Thank You, Paul
    Hope it all goes well!
  • OK ..... thanks
  • PaulButler
    The forum has now moved to its new look and home.
    Please take a look around but before you start to complain that it doesn't look like it used to I will let you know that the underlying software has changed and I have zero control over that.
    Other than that please carry on enjoying this fully paid open forum courtesy of the HET Club
  • ESSX28-1
    ESSX28-1 Senior Contributor
    Looks different but we will learn . Thanks for all your work with these lists.
    David Young (New Zealand)
  • I can work with it........ thanks
  • tigermoth
    tigermoth Expert Adviser
    Sigh.. I cannot find the “start a new discussion “ tab
    regards, Tom
  • PaulButler
    edited February 16
    Tom,
    It's on the right hand side at the top under "New Discussion"
  • dave11
    dave11 Expert Adviser
    How to I remove a hydramatic transmission from the engine?
    have removed the bolts from the bell housing it came about 1/4” then stopped?
  • 54coupe
    54coupe Member
    all those bolts holding the torus cover to the flywheel need to come off too.
  • PaulButler
    I've closed this down as people are just posting random comments in here
