Condenser compatibility
I have these condensers for sale
Check out the discussions on fitment
New Autolite condensers-IGB1025SJ - 1935-39 Hudson and Terraplane — HET Club Open Forum
Condensors don't care what car they are on. All condensers should be within the .18 to .22 uf range.
Thank you Geof.
You have to use a condenser made for an Autolite system. Ones for Ford or Delco will pit your points. You can use any Autolite style but the problem is how and where it gets mounted. Original style is easiest to install and of course it will look correct.
I have ordered Autolite condensers NOS. They are the original style
Condition and quality are probably more important than brand. Vintage NOS condensors could last forever....however sometimes the insulation or wrapping inside begins to break down and they fail. New ones can be just fine, but are more cheaply made. I don't trust any of them to be good just because they have not yet been installed. So test first.
- 102 Hudson 1916 - 1929
- 16 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 554 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 73 Hudson 8
- 597 Vehicles
