Starter Motor Armatures
There are similar armatures from other makes that would interchange with your car . Autolite was the primary electrical supplier to Hudson and as such they had a good bit of similarities with Mopar . Many items will interchange with Hudson electrical components . Problem is how many 39 Dodge starters are there left to interchange? Is your armature an MAB 2113? If so I think I can help.
Yes, according to the 1939 Electrical Service Bulletin it is MAB 2113 and the starter is MAB4075.
As you can see the same armature is used from 1935 to 1947 most models.
Just about all starters are interchangeable to 1947 except for the location of the solenoid.
Ivan L.
I happen to have a 1939 AutoLite parts numbers book. MAB-2113 appears to interchange with no other starters besides Hudson or Terraplane. So, no interchangeability to Ford, Dodge, etc.
However, here's a used one on Ebay: https://www.ebay.com/itm/395049363503
Thanks to all who replied, greatly appreciated.
