Bell housing grease fitting
On my bell housing there is a grease fitting that lines up with the throw out bearing housing. This fitting is on the opposite side of the bell crank that operates the throw out bearing. If needed, I can get pictures of the fitting I'm asking about.
Thanks everyone
Wookie
What are you asking about it?
I will get a few pictures to show everyone what I'm asking about
I know what your'e talking about, but like blondie, I want to know what your question is???
What is the purpose of the grease fitting to push grease into the throw out bearing retainer housing actually for? I can see that the hole is in front of the seal in the throw out bearing housing
Those are to grease the cross-shaft bushings.
I've looked from all angles and that grease fitting doesn't contact the cross shaft bushings at all
Sorry to disagree, it has nothing to do with the cross shaft, but to supply grease to the throw-out bearing. I have had my Essex for 68 years, and have NEVER used this grease fitting. Enough fluid leaks through from the clutch to take care of the bearing.
Thanks for the information. Greasing the the throw out bearing makes sense to me
- 107 Hudson 1916 - 1929
- 564 "How To" - Skills, mechanical and other wise
- 175 The Flathead Forum
- 603 Vehicles
