Tire pressure for radials
Hi everybody! This question has probably been asked dozens of times, but what tire pressure would you use for radial tires on a stepdown? I have a '51 Pacemaker and I am running Diamond Back Auburn Deluxe radials size 710R15. Thanks!
I run Diamondback I tires with a 3" whitewall in a 225/75R15. When I reached out to Diamondback and asked if I need to run a higher tire pressure to keep the wide whitewall from separating, they recommended keeping them at 40PSI. That seemed a bit high, so I bumped them back to 38PSI.
Yes, I also have Diamond Back radials (wide whites, 215/75R15) on my Hornet. They are high inflation high speed tires and DB recommended 44-46 pounds for my application. Their motivation is keeping the white wall straight and prevent separating.
Interesting. I have DB's on my Hornet and actually made a warranty claim for bubbled white walls, they replaced the 2 affected tires. But they never mentioned tire pressure.
This is the tire I'm using. It talks about speed ratings and specifies the inflation rating of 44PSI.
It's probably worth talking to a rep to be sure what's right for you. I dont know if OP is using these or not of course!
- 115 Hudson 1916 - 1929
