Anyone have a source for hubcap sring clip rivets ?
So one of my wheels is missing a hubcap spring clip. I have a extra wheel to source the spring part but I am not sure how to attach it. I can use a bolt or maybe pop rivet but I am afraid it will throw off the balance of the wheel when I get on the new tires put on. Might not be a big deal but was wondering if anyone else had this problem and how they solved it. It's a 1948 hudson commodore.
Thanks,
John
  • 35 Terraplane
    35 Terraplane Senior Contributor
    Had one missing on my 35T 4 bolt steel wheel. I acquired a few from two different sources. None matched the original shape. Made a fixture of a piece of round welded to a piece of angle. Clamped that and the acquired clip and rebent it to fit. Several back and forth's. Turn out useable. Used a bolt, L'w & nylock. Had it checked for balance. I have the clips here someplace if you want to give it a whack I can mail you one for the post cost. Could be these may be the profile you need. Not sure if I can post more than one pic so here goes
  • barrysweet52
    barrysweet52 Expert Adviser
    A lot of wheels are too rusty to be used. However the clips are well worth saving. I have saved a few of these clips knowing that they do break. So check your old rusty wheels or club members with the same year car who live close to you.
  • bob ward
    bob ward Senior Contributor
    I've been in the missing hub cap clip situation with 36 wheels. I used clips from step-down wheels, the clips needed to be massaged slightly to suit their new role. Held in place with a small bolt and a nylock nut. Balance issues are a non-starter for this mod.
  • charles4d
    charles4d Expert Adviser
    Ebay
