Header Build for 212ci (little 6, super 6)
I’m working on building a header flange & ultimately a set of headers for my 37 Hudson’s original 212ci engine. Does anyone have original drawings that might show the center on center specs of the exhaust manifold/block studs &/or block ports?
Yesterday I CNC cut a 16 gauge steel test flange based off an old one piece gasket. After test fitting on a spare engine, doing some tweaking & taking more detailed measurements, it would really help to have factory measurements if at all possible.
I do not know if this will help, but the HET patents with drawings and measurements are online for many Hudson, Essex Terraplane products.
Good suggestion, I always forget to look there… Thanks!
You will get usable measurements using a digital vernier. The stud centres will most probably be on 1/16" increments, maybe 1/32".
Good stuff, what are your thoughts on primary pipe diameter and length, collector and exhaust pipe diameter?
- 110 Hudson 1916 - 1929
- 177 The Flathead Forum
