Electric fuel pump
Where is the best location to install an electric fuel pump on a Stepdown? The pump is the pusher type which I'm told needs to be below the tank as it is gravity fed.
  • 50C8DAN
    50C8DAN Senior Contributor
    Is this to be your main pump or is this a booster pump to prime the carb? I put a booster pump on the rear outside frame rail, just tapped into the metal fuel line back there.
  • JasonNC
    JasonNC Expert Adviser
    It's going to be the main pump. I removed the mechanical pump and blocked it off. I think I will use the same location that you mentioned.
