1926-1929 SUPER SIX DRIVERS DOOR MECHANISM
I AM LOOKING FOR A DRIVERS DOOR MECHANISM FOR A 1926 TO 1929 HUDSON ESSEX SUPER SIX
ANY IDEAS WHERE I CAN SOURCE ONE?
I think that if at all possible, you should try to find someone to repair what you have, including making new parts for it if necessary. Sure, you can try to find one, but it will be unlikely. Just my two cents.
What is wrong with yours?
COIL SPRING INSIDE HAS BROKEN
Are you able to take photo - is it in shape of spiral flat coil with ends that hook on to housing? Gert (retired machinist)
THIS IS WHAT HAPPENED
Just replace it. They are available. Try www.restorationstuff.com
I think you actually mean spiral spring.
yes--sorry--lol!
RESTORATION STUFF-- has none in stock and cannot get any more they said.-- anyone have any other ideas??
Here are photos of a selection I have - will need dimensions - Restoration Stuff seemed too easy - should have removed their offerings when out of supply. Will sell some - but can't at what $5 they had it? Don't know if I have anything that will work. Can you make out the applications? Gert
wow!!--you have a good selection.-- this is what i believe i need with specs.
it looks very close to the bright green one in your pic of assortments?
i would not expect you to sell it for $5-- if you think it will work, i will pay you what you feel it is worth?
Thanks for the dimensions -will check. Please email me at HETgtkristi0@gmail.com (remove HET and 0 is zero). Gert
i got one that was CLOSE so i used a brazing torch and bent it to what the original was
still works fine after 3 years
Good luck
- 112 Hudson 1916 - 1929
