rebuild kits
I'm trying to get my '53 Hornet running but I need a rebuild kit for 2 WA1-2113-S carbs and an AC- combination model DG fuel pump. Any help would be appreciated.
J Lombard
Have you tried Wildricks? Also, you can check with Albright vintage coach depending on where you live. Both are good to deal with.
Wildriks had the carb kit. Thanks Val
For the AC double action fuel/vacuum pumps I've also had good luck with https://www.then-now-auto.com and https://cowboyjohnsautoparts.com, although neither are affiliated with the HET club.
Jeremy Burris in Kentucky may have the fuel pump rebuild kits.
A word of caution about rebuilding double-action fuel pumps. They are not exactly the easiest to rebuild if you haven't done one before. The action mechanism is tricky to get back together, and you might want to see about finding someone skilled to do it.
thanks all for your suggestions.
J Lombard
J Lombard, I can rebuild your WA-1 2113S carburetors, and the AC double action pump. Some of the 53's as well as the 54-56 308's used the later AC double action pump with no bowl on the bottom. I have a kit on hand for the later style pump. I am currently rebuilding two of the earlier 48-52 pumps with the metal bowl on bottom.
- 120 Hudson 1916 - 1929
- 612 Vehicles
