Just so people are aware
Part of that is that is because this forum needs to be upgraded to a later version of PHP.
Because the underlying software is old it's not a simple job so there will be periods where the website will not be available to use and that period may be a couple of days.
Thanks for undertaking these necessary changes in order to make the thing work more smoothly. And thanks for the years you spend keeping the forums humming along.0
Thank You, Paul
Hope it all goes well!
OK ..... thanks
The forum has now moved to its new look and home.
Please take a look around but before you start to complain that it doesn't look like it used to I will let you know that the underlying software has changed and I have zero control over that.
Other than that please carry on enjoying this fully paid open forum courtesy of the HET Club
Looks different but we will learn . Thanks for all your work with these lists.
David Young (New Zealand)
I can work with it........ thanks
Sigh.. I cannot find the “start a new discussion “ tab
regards, Tom
Tom,
It's on the right hand side at the top under "New Discussion"
How to I remove a hydramatic transmission from the engine?
have removed the bolts from the bell housing it came about 1/4” then stopped?
all those bolts holding the torus cover to the flywheel need to come off too.
I've closed this down as people are just posting random comments in here
1
