Stepdown 4 dr rear door glass
kamzack
I'm Stumped, trying to remove door glass from passenger side rear door. I've removed door cards regulator but can't find the combination to removing da glass. I'm sure it's an easy process, I haven't found it. I loaned my body manual an don't want have to buy another. Would appreciate some guidance, please.
Kim
You have to remove the u-shaped window channel from the door first. Then you can rotate the glass 90 degrees and pull it up through the opening.
Thank you . That's what I've been trying. Not much left of da "U" channel. I'll let ya know. Sometimes things are so difficult, they're simple.
Kim
Glass comes out the top.
