Stepdown 4 dr rear door glass
I'm Stumped, trying to remove door glass from passenger side rear door. I've removed door cards regulator but can't find the combination to removing da glass. I'm sure it's an easy process, I haven't found it. I loaned my body manual an don't want have to buy another. Would appreciate some guidance, please.
Kim
  • ratlee2
    ratlee2 Expert Adviser
    edited March 12
    You have to remove the u-shaped window channel from the door first. Then you can rotate the glass 90 degrees and pull it up through the opening.
  • kamzack
    kamzack Senior Contributor
    Thank you . That's what I've been trying. Not much left of da "U" channel. I'll let ya know. Sometimes things are so difficult, they're simple.
    Kim
  • kamzack
    Glass comes out the top.
