1933 clutch fluid
Hello, I have owned a ‘35 Terraplane for 20+ years. I use Hudsonite fluid in the clutch. I recently purchased a 1933 Essex and the owners information manual says “use a mixture of 1/2 kerosene and 1/2 engine oil”. Is that what people are running in their 1933 clutches?
regards, Tom
I use the Hudsonite clutch fluid. Doug Wildrick sells it.
thank you
My father ran Hudsons from late '30s to mid '50's, he used the 50/50 mixture you posted. Never had a problem. I have been using ATF.
There is nothing specifically different about a '33 clutch, as far as lubricant is concerned. What has changed is the specifications of oil and kerosene. In 1933 oils did not have friction modifiers, and kerosene was "oilier" than today. If you were to mix modern multi-grade oil and kerosene it would do the job perhaps, but will more than likely cause bit of shuddeer when engaging, due to the increased "slipperiniss" of the mix. Stick to Dexron 3 or replacement Hudsonite.
Thanks Geoff, I did not know what was in the clutch so I drained, flushed and used Hudsonite from the club
regards, Tom
