Glove box 1933 Essex
Hello, I purchased a car that has a locked glove box and neither key the previous owner supplied seems to work.
any suggestions would be well received.
For example, when working as an aircraft mechanic decades ago, had a tool box key that would open and start all airplanes from a specific aircraft manufacturer.
something like that.
regards, Tom
Turns out the lock was not latched.. just the door did not “pop” when the button was pushed and I did not want to pry it open. I finally figured it out opened the door, removed the lock. In :30 min and $40 dollars I had a key that would work.
the glove box door in the car is beautifully done faux burled walnut, but it is just 2 pieces of sheet metal with a seamed edge all around. Not sure how the door was from the factory.
regards, Tom
Glove box door has a hinge bracket spot welded along the lower edge.
