1937 Terraplane paint codes sheet 4
I searched the site for paint codes for my ‘37 model 72 but could not find any information. This sheet was included with the recent purchase of mine so I thought I would send it along. Note at the bottom of sheet there is a 4801 midnight blue and 4811A Royal maroon. It also says “see sheet number 5”, so I am wondering what other colors might have been available for 1937.
Note: I tried uploading the sheet as a JPEG, as a PDF, as an attachment, as a photo and kept receiving “validation failed” …was so damn frustrated I quit. Wish y’all could see it as it is from 1947 Acme Proxlin, Hudson Terraplane color bulletin number 4.
i’ll try again later after the steam cools off.
This may help, it's from the Dupont Catalog
There is an imposed limit as to the size of uploads , nothing I can change about it. Try reducing the size to , say , 50% and see what happens.
I'll say it again as I've said before. This site is maintained on a reasonable endeavours basis by the club, the software it runs on is no longer supported and to move it to a supportable version would cost the club money so that isn't going to happen.
Paul, what is the max size a PDF can be?
The best I've managed is about 1,000MB - it can be a little ornery at times to say the least. It should be a configurable item but changing it seems to make no difference at all
Thank you Paul, I wasn’t aware of the size limitation and the notification doesn’t specify
No , it's a rubbish message .... took me a while to work out what it actually meant
- 81 Hudson 8
