Removing starter
Need some help removing the starter from my ‘36 Hudson 8. I removed the nuts on the top and bottom bolts of the bracket. The starter is loose on the bolts but I can’t get the bolts out. Is there a clip or some other mechanism holding the bolts in place? The top bolt is in from the engine side, the bottom is in from the transmission side, and neither one will come out so the starter is sandwiched between the bolt head and the bracket. There’s a fair bit of oil and dirt caked on and I’ve done my best to scrap off enough to see but I still can’t figure out why it won’t come off!
Jeremiah
It has been awhile, and I have a couple different cars I work on, but on a couple of cars (might be a different make, it has been 20 years since I had my ‘35 Terraplane 6 engine apart. I have seen (perhaps on another make???) where these are not bolts, but threaded studs with a center collar that fits between the block and the adapter plate keeping the studs in place. Nuts are fitted on the starter side and the adapter plate side.
Next time I am at the shop I will look at my ‘35.
regards, Tom
My 35 T has the bolts as Tom described with a center collar. The bell housing has a recess the studs go in and the studs are sandwiched between the rear motor adapter plate and bell housing. It can be tough to get at the nuts loosened but can be done. It was much easier in I have an old snap on starter box wrench 1/2"-9/16" that is curved.
You have to remove the nuts from the front of the studs. If the studs are turning, then you have to tighten the rear nuts firmly, and if necessary put a lock nut behind and tighten together, and hold with a wrench as you undo the front nut.
