Wiring Diagram for 49 Overdrive
Anybody have a scan of the '49 overdrive wiring diagram?
My email:
HETsierram37@hotmail.com (Drop the HET)
Thanks
My email:
Thanks
Thanks for the info. There is alot good data in that manual. However, the manual doesn't cover '49 Hudsons because they are different from other cars overdrive wiring. So I still need the wiring dagram.0
Ok, how about this. I posted this on the Hudson and Essex Super Six Online Library. A bit out of the norm for this page...but what the heck
http://hudsonsuper6.tripod.com/48-9ODWire.jpg0 -
Hi I'd Like To Tell You Of The Short Cut Wireing We Use On Our Over Drives It's Just S Simple Lead Wire From The Ing Switch To A Fuse Then To A Switch Mounted Under The Dash (where You Can Get At It Easy) The A Wire To The O.d. Selenoid You Will Have To Put A Jumper Wire On The Selenoid
With This Wireing You Will Not Have To Rev The Engine Us To Kick Out Of Overdrive When On A Longhill Just Flip The Switch And Pause On The Gas A Second And Your Out Of Overdrive0 -
Thanks everbody! I got the overdrive working. It was a corroded fuse and fuse holder.0
- 120 Hudson 1916 - 1929
- 612 Vehicles
