6 volt electric fuel pump question
Jim
The way I see it is it doesn't matter if your car is + ground or - ground it is the way you hook up the pump I got my 6 volt pump from motive parts it said - ground all I did was hook up the the + red wire to the ground and the - black wire to the hot wire it works fine MOST TIMES THE GUYS AT THE AUTO PARTS STORE KNOW NOTHING ABOUT WHAT WE ARE TALKING ABOUT (THEY HAVE THIS YOU WANT FRYS WITH THAT LOOK ON THE FACE) WHEN WE ASK FOR SOME THING WITH POSTIVE GROUND I hope this helps you and good luck
Hudsonly
PAULARGETYPE0 -
JC WHITNEY Has 6 V Positive Ground..I bought one from them last Feburary....0
Go to any NAPA. THey have a By-pass 6 volt fuel pump. It is mabe by Bendix. It will work both positive nad negitive ground0
NAPA also has a Carter (NAPA) type 6-volt electric fuel pump, P/N P4259 that will work + or - negative ground and is a very quiet running reliable pump for about $90. It has provisions for an inlet filter to be attached.0
- 103 Hudson 1916 - 1929
- 28.5K HUDSON
- 172 The Flathead Forum
- 599 Vehicles
