Motor Mount & Oil Pump Questions
I have a 1956 Hudson Hornet Holleywood with the 352 Packard V8.
I need to find the motor mounts, found one broken and one cracked.
Also, I need the oil pump and strainer, the pump has the number 471083 on it.
I have contacted Kanter, but they are not sure the Packard mounts will fit the Hudson or if the pump is available.
Thanks for the help.
Gary
Gary
HI I'M PAUL SCHUSTER THE 55,56,57 TECH ADVISOR FOR THE CLUB YOU WILL HAVE TO GET YOUR MOUNTS RECAST
YOU SEND IN YOUR OLD ONES AND HE REUSES YOUR STEEL PARTS WHEN HE RECASTS THEM
THE PACKAED ONES WILL NOT FIT
I HAD MINE DONE AT
ANTQUE AUTO PARTS CELLER
# 6 CHANCY ST
PO BOX # 3
SOUTH WEYMOUTH MASS 02109 PHONE
# 781-335-1579
I THINK THE GUYS NAME WAS TOM HANAFORD THEY COST ME $50 EACH 3 YEARS AGO HE ALSO DOES THE REAR MONTS
NOW THE OIL PUMP YOU CAN REBUILD YOUR SELF AND SAVE SOME $'S DOING IT ORDER A OIL PUMP REBUILD KIT FROM DALE COOPER IN CINCINNATI OHIO HIS # IS 513-821-6200 9 TO 5 WEEK DAYS
I WAS VERY HAPPY WITH THE PRODUCT AND HE DID THEM IN A TIMELY MANNOR I HOPE THIS HELPS AND IF YOU NEED ANY OTHER INFO YOU CAN REACH ME AT
HETHUDSON1957@AOL.COM REMOVE THE HET FROM THE EMAIL ADDRESS IT JUST THERE TO KEEP THE SPAMERS AWAY
HUDSON HASHLY
PAUL SCHUSTER0 -
Paul Great Job, Helping People On Their 55,56, And 57s. I Have Passed This Info Onto One Of My Customers Who Has The Same Motor Mount Problems. My Specialty Is Not Hashes. I Keep Busy With The Earlier Cars. So It Is Nice To Have Someone With Your Experience To Help With These Models, Bill Albright0
Thanks: I'll get on the phone Monday morning.0
Packards' International makes a new oil pump that will not suck air, and works better than the original pump. They need a core exchange. I had problems with my stock pump, when the engine was one quart low on oil, the bearings burnt up! Had to have the Packard 352 engine completely rebuilt with the new oil pump !0
- 120 Hudson 1916 - 1929
- 612 Vehicles
