Twin-H
yup! should work fine!0
hudsonkid wrote:yup! should work fine!
While I think this will work fine, Isn't there a slight difference in the carbs? And of course there might be a difference in linkage on the automatics and standard transmissions and possibly short to long wheelbase. I think Bill A. mentioned on the later manifolds the carb bases are smaller on the twin H wasps (hashes).0 -
Jim G wrote:Will the twin-H set-up (Carbs, manifold, linkage, cleaners) off of a 262 work on a 308 engine?
Jim G
It will bolt right on and should work, but 262 used different manifold, as it had smaller carbs than 308. You won't get full advantage of twin H, You will be better off traning the intake and carbs for ones from 308.0 -
Jim G
Hey you guys!!!! all he wanted to know was whether it would work, c'mon....
hudsonkid wrote:Hey you guys!!!! all he wanted to know was whether it would work, c'mon....
Work or work properly? It is like using 14 inch wheels from a Hash, they will will work. LOL0 -
Well Dave On A 57 Hudson They Will Work Just Fine !!! Lol0
- 120 Hudson 1916 - 1929
- 612 Vehicles
