Grommet, steering column and shifter at toeboard
On some photos I have of some 1949 and 1950 hudsons, I have seen a one piece grommet on the steering and shifter column that closes out the carpet on the toeboard. Does anyone know where or if these are available. I looked through K-Gap and did not see one.
Thanks
Thanks
The Grommet is a piece of rubber designed to keep the shift lever rod in place and act as an anti rattle item. The floor is closed out with a flat piece of rubber which has holes for the steering tube and the shift rod.
You can cut this item from stock rubber sheeting. The thickness is around 1/16 inch.
Hope this helps
[image]http://members.aol.com/stepdown53/53HAUL.gif
[/image] BR
Ken Cates
Hudson Affecitonato
Waco, Texas
Full Line has the seals if they are still in business.A rubber seal goes under the carpet and one on top of carpet.
Billy K.0
