Lifter cover gaskets 308
I have the valve cover sets. Fresh stock. $13.00 & postage of $4.00
Randy Maas
P.O. Box 589
Manito, Ill. 615460 -
I made my own out of a sheet of cork gasket material. it was easy.0
Jimalberta wrote:I made my own out of a sheet of cork gasket material. it was easy.
If you make a set, make two. usually easier to make a couple, if you're going to use them in a timely fashion. Also, don't forget the "washers" for the bolts.0
- 184 The Flathead Forum
