Thermostat Housing Bolt Torque
Unknown
What is the correct torque for the two bolts that hold the Thermostat housing to the head? I just got my new thermostat and gasket today.
Currently I have them at 25 pounds.
  • dwardo99
    dwardo99 Expert Adviser
    I don't know but that sounds like enough. If it leaks, take the thermostat out of the housing and make sure the little groove where it seats is perfectly clean. I've had it happen that some crud kept the thermostat from seating all the way fluch and it held the housing off enough to cause a leak.
  • nick s
    nick s Senior Contributor
    20-30 Ft-lb is per the book
  • Geoff
    Geoff Senior Contributor
    It's also not uncommin for the bottom surface to be less than ideal as far as straightness is concerned, with a bow in the centre. Test it against a straight edge, and if necessary dress it flat.
    Geoff.
  • Thanks all. Got it installed correctly and no leaks (I got it running today!!!!).
