Hudson Wheel interchange
Is there a modern replacement for the Old 52 Hornet rim that can still be purchased brand new. I do not mind if the rim is half inch wider for the radial type tire. Does anyone know what could be used and purchase over the counter from a place like NAPA.
Thanks
Thanks
I believe that hudsons have a 5 on 4.5 bolt bolt pattern, which is the same as most RWD AMC, Ford and Chrysler cars
You should be able to get wheels at almost any Junkyard0 -
Problem with the wheels mentioned is that they do not have the hole for the locating pin. YOu can go to a supplier and get a uni-lug wheel. IT has both the 4.5 and 5" hole pattern. Thess SHOULD have a lug hole which lines up with the locator pin. The pin won't be much good for locating, but using theis methosd you will not have to cut off the lug.
Also, don't use Chrysler wheels the lug hole is designed for a smaller nut. The Hudson lug bolt won't fit properly0 -
We bought a set of Lincoln mag wheels for our 51 Hornet convertible. Drilled the pilot hole in them for the guide pin. Worked great. These are the older rear wheel drive Lincoln wheels.0
Do you have any pictures of thoe lincoln wheels on your hudson? I had been thinking about ford LTD wagon wheels.0
Chrysler wheels through '64 or '65 have the guide pin holes generally. This gives you a wide range of possibilities. Ford LTD wheels will fit if it is not the oddball that used the 5 on 5 pattern.0
- 110 Hudson 1916 - 1929
- 177 The Flathead Forum
