u-joints
Unknown
I was told that the Jet's u-joints are the same as some Chevrolets. Is this true? Does anybody know which chevy or a number that I can use.
Thanks, Barry Smedley:D
  • Geoff
    Geoff Senior Contributor
    I don't know which model Chevy they are from but there is certainly nothing unusual about the U-joint. I took mine into a local parts shop and bought one off the shelf (I'm in New Zealand). They just looked it at it and and went and got the new one to match.
    Geoff.
  • 53jetman
    53jetman Senior Contributor
    Barry - GMB 200X u-joint fits the Jet as well as the step-down and earlier model Hudsons. This unit is a HD model with grease fittings
    Jerry Bean
    HudsonJetman@hotmail.com
    HET Jet Technical Advisor
  • PAULARGETYPE
    PAULARGETYPE Senior Contributor
    1936 TO 1954 HUDSON SAME AS
    62 TO 72 CAMARO,CHEVELLE CHEVY NOVA,NOVA EXC TRRBO HYDRO
    55 TO71 CHEVY 1/2 TON 3 SPEED
    67 TO 70 CHEVY 3/4 TON 3 SPEED
    63 TO 70 FALCON V8
    AND MAY BE OTHERS
    http://members.aol.com/sanjuana/Images/HudsonSwapsManual.pdf
    PAGE 46
    LOOK AT THIS WEB ADDRESS IT IS A HUDSON SWAPS MANUAL PUT
    TOGETHER YEARS AGO BY LEU BACKHAS
  • mars55
    mars55 Senior Contributor
    Try NAPA 2100153 or Precision 369.
  • Thanks Guys! One more question, Is the joints for the overdrive the same??
    Thanks for the help!!
    Barry Smedley
    Anyone have an updated NAPA number for the carrier bearing?
    Mark
  • Yes the overdrive transmission uses the same GM style joint as posted above
  • mars55
    Mark
    Well I found the following:
    '48-'52 All Exc Pacemaker and Wasp use #88506
    '50-'52 Pacemaker and Wasp use #88107
    '53-'54 All Exc Jet use #88107
    I am not totally sure about the above infomation. So here are the dimensions of the bearings. You can measure yours and pick the right one.
    #88506
    ID 1.1811 inchs
    OD 2.4409
    Width 0.9449 inchs
    #88107
    ID 1.3780 inchs
    OD 2.8346
    Width 0.9843 inchs
    #88506
    ID 1.1811 inchs
    OD 2.4409
    Width 0.9449 inchs
    #88107
    ID 1.3780 inchs
    OD 2.8346
    Width 0.9843 inchs
    Thank you very much, I appreciate the info.
    Mark
