Free Wheeling ?
not sure just what years i think 30 to about 32 it's like taking the car out of gear and drifting or free wheeling as Hudson called it
AKA Georgia Overdrive.0
Hudzilla wrote:AKA Georgia Overdrive.
Chevy came out with it in !932 and had it for a couple of years- its some kind of one way clutch behind the trans - when you let off the gas the car coasted till you put power back against it or locked it out manually . a real poor deal in a Chevy coasting down a hill with mechanical brakes !!!!0 -
But a huge advantage for those who could never master the technique of double-de-clutching to change gears. With the free-wheeling option, you just pushed the gear lever through, no crunching! Certainly disconcerting though with mechanicla brakes and steep hills. If you tried to engage direct drive whilst free-wheeling faster than the engine was running you were likely to disembowel the unit!
Geoff.0 -
About the same thing as driving a overdrive car at speeds below 20mph when the OD handle is pushed in. Most every manufactor except Ford had it in one way/name or another. Not something you use with bad brakes.0
- 184 The Flathead Forum
