part numbers for brakes
Hi All,
I need some help with some part numbers for the brake system on my '49 super 6. Ineed some part numbers for front brakes shoes and numbers for a master cylinder. I am finding most of what i need at Autozone. Any help will definately be appreciated.
Hudsonly, Lisa G.
Hudsonly, Lisa G.
Brake interchange information: CAUTION carefully compare the interchange part with your original part, before use.
1948 -1954 Hudson Master Cylinder- WITHOUT POWER BRAKES-Napa/United # 3081
1948 -1954 Hudson Master Cylinder Repair Kit - W/O POWER BRAKES Napa/United # 138
1951 -1954 Hudson Front Brake Shoes - Raybsetos #263
1951 -1954 Hudson Rear Brake Shoes - - Raybsetos # RR-55
1948 -1954 Hudson Front Brake Shoes - 11" X 1 3/4" - Napa Rayloc# RS-55
1948 -1954 Hudson Rear Brake Shoes - 11" X 1 3/4" - Napa Rayloc# RS-55
1948 -1954 Hudson Front Brake Shoes - 11" X 21/4" - Napa Rayloc # RS-18
1952 - 1954 Rear Brake Hose - Wagner #24404
1952 - 1954 Rear Brake Hose - Napa/United 11149
1948 - 1954 Front Brake Hose - EIS SP-1418 or Napa/United 10303
1951-1954 Wheel Cylinder Repair kits - Front Raybsetos WK-13
1951-1954 Wheel Cylinder Repair kits - Rear Raybsetos WK-36
Wagner/Lockheed Number for rear wheel cylinders for 1948 -54 Stepdowns FD-2447
Bendix Numbers for wheel cylinders for Stepdowns 1 1/8 inch cylinders 3128 ( left) , 3129 (right)
Bendix Numbers for wheel cylinders for Stepdowns 1 1/16 inch cylinders 3461( left) ,3462 (right)
EIS Numbers for wheel cylinders for 1952-1954 Pacemaker / Wasp Stepdowns 1 1/16 inch
New stepdown wheel cylinder numbers courtesy of Uncle Josh
Wheel cylinder Coni-Seal WC13600 40-54 Hudson LR 15/16 in Bendix 33600 Midas 1024 Wagner 59240 Auto Spec 84001 EIS 9150
Wheel cylinder Coni-Seal WC13221 48-54 Hudson RF 1 1/8 in Bendix 33221 Midas 1031 Wagner 18291 Auto Spec 84010 EIS 40025
Wheel cylinder Coni-Seal WC13601 40-54 Hudson RR 15/16 in Bendix 33601 Midas 1025 Wagner 59241 Auto Spec 84002 EIS 9151
Wheel cylinder Coni-Seal WC13220 48-54 Hudson LF 1 1/8 in Bendix 33220 Midas 1030 Wagner 18290 Auto Spec 84009 EIS 400240 -
the Master cyl lis a WAGNER 3081 my cost at napa 75.00 I retail them at 100.00 good luck Bill Albright0
If AZ or NAPA do not have the brake parts, CarQuest should. I got all my brake parts (shoes, cylinders, etc.) at CQ.0
cailynne wrote:Hi All,
Hudsonly, Lisa G.
Lisa:
Hope you can balance raising your family and bringing your HET back to life. I know how that goes. But, in my case Hudson was the car I drove so it was repaired as needed to allow me to travel to and from work each day. To ease your trials and tribulations may I suggest that you check my web page occasionally... I try to put information there that is just for folks like your self ... trying to return their Hudson to operation. Dave S grabbed the brake information that is there .... and added UJs new data... will grab and post that too ... soon.
There is some other Brake information at this URL
http://members.aol.com/stepdown53/STEPDOWNRESTORATIONAIDS.html#BRAKES
Good Luck and keep pushing forward... the car will be back in operation sooner than U think...
BTW... if you need assistance... have the next chapter meeting at your house. Prepare a list of things U need help with and enlist the time and talents of your chapter members... I have done that before and had a wonderful time.
Ken
Thanks for all the help guys, I've got the stuff ordered and on its way, thanks ken for the link i'm sure it will be a great help in getting my car on the road.
Hudsonly, Lisa G.0
- 596 "How To" - Skills, mechanical and other wise
